disable vpls health-check vccv
disable vpls [vpls_name | all] health-check vccv
This command has been replaced with the following command: disable l2vpn [vpls [vpls_name | all] | vpws [vpws_name | all]] health-check vccv .
This command is still supported for backward compatibility, but it will be removed from a future release, so we recommend that you start using the new command.
Description
Disables the VCCV health check feature on one or all VPLS instances on the local node.
Syntax Description
vpls_name Identifies the VPLS for which health check is to be disabled.
all Specifies that health check is to be disabled on all VPLS instances on the local node.
Default
Health check is disabled.
Usage Guidelines
None.
The following command disables the health check feature on the VPLS instance myvpls:
disable vpls myvpls health-check vccv
Platform Availability
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
